Hi everyone,
I decided to take off the running boards the other day and i was able to take off everything except one thing....
The left rear bracket will not come off due to the bottom bolt that holds it in. Basically, the best way i can describe it is, it just keeps spinning. It seems that the thread (i'm guessing it's a nut) that it runs through has somehow came loose. Now I am stumped as i have no idea on how to get access to the backside of the nut (if it is one) in order to prevent it from spinning while i try to remove the bolt that holds the bracket it.
I did think about cutting the head of the bolt off, while that will help me remove the bracket, i am afraid that the bolt will just fall into the body later on (since the nut that holds it in place is also loose) and will cause some rattling issues later on.
Any suggestions would be appreciated.
Thanks.
Thanks.
did they weld it on in the first place!!??
