RTH- B Pillar Interior Trim Removal
Houston, Texas
For ‘19 200. Can someone post instructions? Thanks!
cute photo for your troubles
Which part? Top/bottom or both?
Ah - remove front kick trim (pry at seam next to B pillar) - remove second row kick trim (pry up the square on the ribbed step section and undo 10mm bolt) by prying from step forward. There is a bit of trim covering the seatbelt LOWER bolt - pull up to remove, then the pillar should pop off (clips all around)
Thanks!
Current state of the interior 😳
