ATwoZ
I'm in the middle of an AHC Globe Replacement following and relevant mud thread.
We went through and bleed DF, DR, DF then replaced DF Globe, then re-bled DR and replaced DR Globe.
Then did the same thing on the opposite side in same order. No issues with Globe removal or bleeding.
Refilled reservoir to a bit above the midway of reservoir (past-Max) knowing we'd be bleeding again.
I got the AHC error on the dash, but if I flip to on without starting and flick up the switch the pump kicks on.
The issue is even after many minutes there's no movement in fluid levels or vehicle. We've tried checking bleeders and all but DR will expel some fluid. DR will not expel fluid. Trying to start the car just gives error.
