Rough Running 60
  • Thread starter Thread starter oldgrey60
  • Start date Start date
O
oldgrey60
Guest
Since new my 87 FJ60 will not run without bad low rpm stumbling if EGR is operational. Beaded air line to EGR runs great but with minor high rpm pinging? I know a non operational EGR valve will cause pinging but FJ is undrivable when operational, any help???:confused:
Correction to rough running 60
After reading a thread called "hesitation" seems I have the same issue. It's not the EGR valve but the EGR Modulator vac line that I have plugged. If the modulator vac line is unplugged FJ stumbles and hesitates at low RPM driving. What do you all think?
i had a similar problem when i first bought mine. i put in a new pcv valve and bought a used egr from landcruiser parts and it runs much better. i don't know which one fixed it but try the pcv for sure, it's cheap and easy to do.
andy
