For the past 6 months I've been trying to trace down a rough idle. It's started around the same time I had my alternator replaced. There is a ton of information on here about various things that people have done to try and fix their idle issue. I wanted to start a new thread since I've read them all and still have not fixed my issue. No CEL and everything looks fine according to my Scangage.
Symptoms: Rough idle when sitting at a stop light with the truck in drive. Less noticeable with A/C on since RPMs are higher. Shifting to N appears to alleviate the issue. At HIH I noticed less of an issue when at over 10K+ feet. RPM at stop in Drive with AC off is around 600-620. My mechanic who's well versed in all things Land Cruiser is stumped & I am tired of throwing parts at this.
Here is what I have replaced / tried - all OEM parts
1. Fuel Filter
2. APPS
3. TPS
4. 8 new Denso coils/plugs
5. Clean MAF/Throttle Body
6. Had mechanic clean fuel injectors
7. Replaced air filter
8. Mechanic checked for vacuum leaks
9. O2 Sensors
Any suggestions on what I should try next?
Thanks
SDCruiser
1. Fuel Filter
2. APPS
3. TPS
9. O2 Sensors
Thanks
SDCruiser
