roof light bar
Ebay Light Bar
I have the light bar installed with four KC's. I get alot of compliments. The wiring was a bit tricky because KC wiring is cumbersme due to relays and so on. I used 12 guage wire to run it through the bar and cab to the battery then attached relays. If you try to combine two sets of lights on the same light control switch your car will most likley light on fire after 20 minutes of use. Dont ask me how I know that. The bar works great other than the tight wiring space. go to www.myspace.com/bluegrenade to see more pics for reference.
Matt
