I plan to do a bunch of stuff on my cruiser here soon when the ground firms up including iron Man lift, Bilstein shocks, all new brake soft lines, new rear control arm bushings, fixing the rust on my rocker panels, and cleaning all the salt off and under coating.
So the 12" area in front of the rear wheels on both sides that is the outer rocker panel needs to be replaced. I have no problem doing this but I need help with the painting side. I'd like to use a 2 part epoxy primer with like two coats or so to do the inside of the panel. I have a couple different spray guns I have access to, one may need a rebuild but anyway. How would I spray inside the rocker panel? I found online these spray gun extension tips that use a 360 degree spray nozzle they are made by Binks I believe. My problem is I couldn't find a price for the tip or the extension only price I found was for the whole gun and $1000 is absurd for something I won't use more then a couple times...
I figured I could put the extension through the plug holes on the inside rocker panel to achieve my goals but I can't achieve them without the extension and tip. So what have you guys seen or used to spray paint on the inside of confined spaces like this? I don't necessarily need to paint the whole inside of the panel but it would probably benefit from it. I'd just have to figure out how to not plug up the drain slits.
Thanks for any and all replys,
Jeremy
Jeremy
