FREE Rivets
David70FJ40
Older Than Most
High Point, NC
FREE! As in no charge, no $'s.
Didn't use the rivets that were supplied with the CCOT rain gutter so if anyone has use for them I will send them free of charge.
What did you use if you did not use these? This is a job I will be doing very soon.
The hot rod shop used a two-part automotive adhesive so there are no holes in the gutter. Hopefully it will seal up better than the rivets and prevent rust down the road.
Did they weld up the 9 pieces of rain gutter from CCOT? Do you have any pictures of what that looked like?
No photos but I know they mounted the sides on the tub, added the rear header and the braces across both door openings then started to mount the rain gutter before welding. It was an exact fit then off to smoothing the welds and preparing for painting.
