Rigid RDS SR-Series to Switch pros - looking for some help :-)
Redondo Beach, CA
Hi all, maybe someone can help me with wiring for this?
I have Rigid 30“ rds sr-series that I am trying to turn on using the switch pros 9100. The max amperage on the switch pros is 35A and the fuse that’s in the rigid wiring harness is 40A.
Is there a way to use this harness and connect the harnesses switch to the switch pros and then the connect the main power and ground straight to the battery?
If so not sure how the wiring should look because the Rigid harness switch has 3 color wires, red , black, and blue that go to a relay.
you don't need any of the wiring (relay) that came with the light if you're using a switchpros.
The switchpros has the fuse built-in, so just extend the wires from the switch color to the light.
I had thought that originally but does it matter if the 35A on switch pros and the 40A on the harness?
176 watts = 14 amps...
any of the switches will work... you don't need one of the high 35amp ones (5-8).
14-12awg will work, depending on your length.
that's an interesting curved light. Where are you going to put it?
