Retracing History of Head Gasket Replacement
Southlake, TX
One of the reasons I purchased this particular 97 FZJ80 last year is because it has a well documented history. Prior to my ownership, it starred in @shootandcruise YT videos and before that was owned by a gentleman in Shreveport LA who kept every service record, dealership tag, etc. I have a treasure trove of old artifacts to tell the story of its ownership.
All the recent threads on blown head gaskets made me dig into my old service records and I have two invoices from May 24, 2006 & June 6, 2006 for diagnosing a blown HG and a full repair. The ODO at the time was 136,656…fast forward 20 years, and now the ODO is 235,413. Most know by now I’ve R&R almost every part of my cruiser with OEM parts. Every hose (coolant, PHH & vac), component (pulley, compressor, starter, alternator, fan clutch, fan) have been replaced, and I run Toyota Red only.
My rig runs great, does not drip any fluids and operates like a new car, but for those who’ve had a blown HG, is it always the result of some other component failing that causes engine to overheat, or do they just decide to quit one day, no matter how much maintenance you give them?
130k is kind of early. Most I've seen blow past 200k. Your cooling system may have had corrosion issues or they really worked it on hot days. Look for records of EGR issues prior to this - that will tell you if it was plugged up from excess oil consumption.
The replacement HG in your 80 is a redesigned Toyota part. The original HG, while never part of a recall, did have issues uncommon in the Toyota world. Your new HG should get you through the life of the engine, especially as well maintained as you keep your truck.
Usually some other component. On the 80 it's the EGR pipe but for engines in general it's usually a failure somewhere in the cooling system that causes the engine to overheat and the cylinder head to warp. There can be other causes like loose head bolts but generally it's overheating.
As long as you don't let the engine overheat, the headgasket should serve for the life of the engine.
I chased the P0401 with new EGR value, modulator and VSV…took off the manifold and wired the ports plus new hoses. For those chasing this, start with the VSV. All this to say I hope I have the EGR in good order
