Hi to all! I am getting prepared to to do a 5.3 / 4l60e swap on my FJ 62. The donor vehicle is a '03 Tahoe flex fuel that was rolled. I'm in the process of replacing the output shaft to a 2wd unit so that I can use the AA adapter. I was comparing the shaft that I have to others, and it appears that the splines on the end of mine do not extend as far up as on others. My shaft (bottom)
Shaft from previous thread: (on the left)
The shaft in the lower left picture shows the splines going almost to the reluctor ring, vs my shaft, which shows the splines ending a good inch or more before. I know that I will have to cut the end off to use the adaptor, and am worried that there won't be enough spline length for the adapter to work. Also, will I need to install the old reluctor ring, or does the kit come with one that is specific to the adapter? Any thoughts on this would be greatly appreciated! I won't be doing the actual swap till this winter, if there is interest, I will do a thread on the build as I go. Thanks for any help, this forum has been a huge source of information.
