Hi All,
Just went through my first time changing my alternator on my 100. Here's the story:
Alternator has been whining/groaning for over a year now, so I figured the time was coming to replace it. The other night, started the Cruiser and the battery light came on. Lights seemed kinda dim, so it seemed my time had come. Voltmeter on the battery while running was at 11 volts, leading me to conclude it was time to swap the alternator.
Went ahead and purchased a remanned Denso from Amazon (https://www.amazon.com/gp/product/B000C5WBRS/ref=oh_aui_detailpage_o06_s01?ie=UTF8&psc=1)
The body seemed just a bit smaller but otherwise it was a normal fit.
After getting it all installed and taking it for a test run, within a half mile all the dash lights lit up and the lights started to dim. Barely got it turned around and back home before it started to stall out. Now it's all worse than before! Voltage at battery while idling dropped to 7 (super low).
The only thing of note is that it was a PAIN to get the wire plug out. It was stuck in there and took some prying to get out. It seemed the wires were short enough that they were stressed a lot, but none seemed to be to broken from the terminal.
Also, one, the one harness that is anchored to the passenger side I did not re-attached because there wan't a location on the new alternator to do so.
I'm now not sure where to begin diagnosing. Any help would be appreciated greatly.
