Crossposting from the 40 Tech to see the "local" opinion....
So I had to pull the tranny, but that's another story.
I've had an oil leak into the flywheel/bellhousing inspection plate for a few months now and I was sure it was the rear main. I believe she has the original '78 seal in there - at least it hasn't been done since I owned it in '95. Once I got in there, rear main was dry. So I cleaned and baby powdered it up, reinstalled the flywheel and ran it for a few minutes. What I discovered, appears to be seepage of the oil-pan gasket, jut above the rear bearing cap bolt head (that cap was really wet on one side when I first inspected for the leak, pass side).
Well, the oilpan gasket has only been on about 3 years, and is OE and was done right (so I thought). So I checked the oilpan bolts and found all of them took AT LEAST a full turn with one hand on the ratchet, not applying much torque.
Long story short, I'm not going to replace the oilpan gasket (again) until I see if tightening the bolts will fix the leak, but should I go ahead and replace the rear main while I have everything opened up, even though I am 99.9% sure it is not leaking???
R
R
