Repair failed '08 AUX jack for $14 vs $140.
Myrtle Beach, SC
I replaced the failed core of my AUX jack that would no longer detect the phono being inserted. I used the later model core replacement for the
86190-02010 as the 86190-00006 Is not available as a core and oem is 140 bucks. The repalcement core is shorter than the original and requires using a Dremel with rotatry cutter bit to grind the stop back to where it will go all the way in to poke into the front cover. I then used my belt sander to grind the case back flush with the end of the replacement core and siliconed it in place. Works like a charm just have to wait for the silicone to cure and it should be like new, no more unbareably crappy music from the crappy tape adapter I bought as a stop gap measure.
Like to part
Amazon product ASIN B07PQQHK9D
