Wanted Receiver hitch bolts 80 series
Spirit lake, ID
Looking for receiver hitch bolts. I took mine off and didn’t plan on using it again and now need to use it and can’t find the bolts. Let me know what you have and what you want for them. This is for the 80 series factory receiver hitch. Thanks
For what? I just put a hitch on my 40 and spec'd out my own hardware through Fastenal for $7, since I couldn't get the original Toyota stuff.
Yeah I might just figure out bolt thread and get them locally but have not gone down that road yet.
You decide what thread you want, the holes in the bumper are just through holes, no threads. I used a 12mm nominal diameter fastener with nylock nuts. For the hardware that holds on the bumperettes/step , you can still get that through Toyota.
If you are looking for the middle 4 pintle hitch bolts, they are M12 x 1.25 x 50. You will only need 2 nuts (nylock type as mentioned in the above reply) as the top two thread into the frame cross member.
I am looking for the 6 bolts I believe for the standard 80 series hitch that mounts below the frame rails and into the frame rails. I believe they are m12 1.25 bolts but the nuts are welded into frame if I remember right. I am going to take a look tonight and see if I can find mine then may just order some up.
