- Joined
- Dec 20, 2007
- Threads
- 133
- Messages
- 1,138
- Location
- Orcas Island in NW Washington State
- Website
- www.mtpickettwoodworking.com
Finally finishing up my transfer case (79 fj 55) rebuild and this afternoon I torqued the front drive output shaft to 115 lbs as stated in the FSM, then I installed the retainer with speedo drive with the same two shims I had removed. Next step is to install brake backing plate and drum and torque that nut. (I didn't do that because my backing plate and drum are on the old T-case of the still running vehicle) . The next step is to do the spring scale test but FSM says to disengage the front drive first. Well I decided to disengage front drive just to see how things rolled over and sounded that way. Without the lever/handle installed I was unsure which way was in or out for front drive. The plunger rod was currently in the inward 'pushed in' position and the front drive was locked with the rear drive and rotates with expected pre-load drag. So I pull the plunger out, typical friction and detents all good. But... The two shafts still turn together as one. I installed a new rear output gear and new clutch sleeve, but front output gear was like new so it stayed. I was very careful to install the clutch sleeve as in the FSM with the beveled edge facing outward to the installer as in the photo. Granted I have not installed drum and torqued it, and that may change things (?) But now is the time to open it back up if needed. First thing I should know is "Does pulling the plunger rod OUT disengage front drive or does pushing it in disengage front drive?"
