Rear View Mirror
I have one.
I'm about to send you a check but wanted to verify the fit. Here's my mirror mount, is it correct for that mirror?
Also thought I'd check on dash parts while I'm at it, any good parts for the circled section?
Thanks!
Thanks!
The mirror is correct, you must have a '76 or older like me! I have the short lower dash pad and the wreckers have the whole panel that you have circled. The dash changed a little over the years though so things might be a little different.
If you're needing the vent under the dash I think I have that too since I got factory A/C! I didn't see it just now but if I don't have it I think the wreckers did.
Thanks for confirming the mirror! Mine's a '69 so a bit older than yours. I do need the vent which is now covered with cloth tape. :rolleyes: and the panel was hacked for a radio install so I could use that too.
Shoot me a price for anything you have that I need and I'll get the check off asap.
Greatly appreciated!
:cheers:
:cheers:
I will see if I can get the panel from the wreckers.
