Rear springs and longer travel shocks
Just past the middle of nowhere in South Texas
Getting new tires on the Land Cruiser today. Was checking brake pads and reached in to make sure the springs were seated properly. Springs were hanging completely loose. I have Slee heavy springs with ICON stage 3 longer travel shocks. That got me thinking about the suspension articulating when offroad. Any thoughts on whether I should be concerned with the springs slipping out of place when the rear suspension fully articulates? Should I switch to 863s to avoid a problem?
Thanks
Bloomer...... you can easily make a spring retention system to keep the spring captive. There is a hole in the bottom spring perch. A piece of steel slightly bent with a hole drilled through the center, bolted in place will keep it secure forever. That's what I use. You can weld a small retainer right on the perch as well.
Here is a photo from when I was building mine. @bluecruiser was the original designer of this method when we were running the L shocks. I have the super XL ICON's and still use this same system.
Is that the new CAD program
