Rear Sliding Glass Rubber (1 Viewer)
Lexington, VA
Good Morning all,
I am looking to replace my rear sliding glass weather stripping and the runs. On partsouq I only see that the RH sides are available. Does anyone know where the LH runs and weatherstripping can be sourced from or if they are interchangeable?
Partsouq Chart
RH Weather strip:
6274160040 avail​
LH weather strip
6274260050 NLA​
RH Run
6275560010 avail​
LH Run
6275660020 NLA​
I just successfully installed these in my US 94 FZJ80 with sliding windows. I'm pretty sure none of the parts were L-R interchangeable, but I didn't test.
Toyota 62742-60040 - WEATHERSTRIP, QUARTER WINDOW, LH
Toyota 62741-60040 - WEATHERSTRIP, QUARTER WINDOW, RH
Toyota 62756-60010 - RUN, QUARTER WINDOW, LH
Toyota 62755-60010 - RUN, QUARTER WINDOW, RH
If you're going to this effort, I'd suggest replacing the center frame assembly, the vertical bar in the middle. Mine were in bad shape and I paused the project until I got replacements. The felt was worn down to nothing, causing wind noise.
Toyota 67046-60010 - FRAME SUB-ASSY, SIDE FRONT WINDOW, CENTER LH
Toyota 67045-60010 - FRAME SUB-ASSY, SIDE FRONT WINDOW, CENTER RH
(the frame sub-assy description is wrong, but the part is correct. It's for the quarter window.)
Awesome information thank you brother!
