I'm replacing my u joints and finding some conflicting information around the internet, and not finding what I need from the search button on the forums.
I pulled my rear prop shaft out and noticed the two flange yokes are not in phase, they are about 30 degrees off. The truck has no noticable vibration or anything, but something on the driveshaft is squealing at ~2500 RPM hence the u joint replacement.
Can someone confirm the phasing of the rear prop shaft for fj62 (1988)? The fsm doesn't seem to mention it, and it appears from the diagram that the front and rear flange yokes should be in phase (ie, aligned.)
When I reinstall them should I put them in phase as they should be and hope for the best? Or reinstall them as they were when I pulled them off? Or neither, and take it to get balanced?
