Hey guys,
So I believe the reason my EMS exhaust rubs the driveshaft is because my rear end is too low.
Check this out:
Based on a majority of pics I see online... the rear should not be this low. Right?
Now the question is... what is the fix?
Given the AHC, my understanding is that the system will raise the rear until the correct height (or die trying) regardless of how worn the springs are. The neutral pressures will be up, but they will lift regardless until they die.
I can still put it in High and the AHC graduation test passes, so I'm guessing that's not the problem.
Can anything other than sensor position lower the rear end?
Here's where my sensor is: looks unmoved.
Zoomed in:
I don't want to just raise this IF there is another cause outside of this sensor position.
Thanks all!
Check this out:
Zoomed in:
Thanks all!
