Does anyone have any ideas on how to fix a cracked control arm mount. I was thinking welding a reinforcing piece over the damaged area. But my other problem is I don't know what it should look like, does anyone have any pix of theirs?
I don't think the allpro LCA skid is going to do much good to help a cracked mount. You'll need to weld it to at least fix the mount and then you can either go with a bolt on skid or figure out some way to weld reinforcements.
There in lies my problem, not sure if the geometry matters or if it could tweak the alignment if I don't get it fixed just right... Wow this is definitely a time that I should have had the skids on from the beginning!!
Is this the front (frame) or rear (axle) mount? I have damage to both of mine on the passenger side...
Rear axle on both sides. Since they mount to the under side of the frame rails they get to be the lowest point and get the brunt of most impacts that the sliders or frame protect the underside from.
oh that's not bad at all, no big deal. you can try to bend it back a bit if it's touching the control arm or causing binding.
a simple piece of plate metal welded on top or one of those skids linked earlier would be good to put on there otherwise, i'd just leave it be.
