Rear coil heights
Cairo, Egypt
Just received a pair of Dobinson coil springs. One of them is marked left side, the other one's label is torn off.
Since I did not receive them in a box, I am thinking maybe the other one is not the right side. Could be another left side.
The unlabeled one is 490mm, the left hand side is 495mm high.
Is the left side normally higher? or is it the other way around?
Thanks.
The longer one is 'usually' for the side of the vehicle with the fuel tank. Can't say for sure.
Well, I found out the LHS is one cm taller than the RHS. As per Dobinson specs.
I would assume all other brands would be the same, for LHS drive cars.
Longer spring goes on driver side. Some old man emu stuff was backwards for us in the states since drive is on diff sides.
