Hi all
Does someone have a list of the Toyota part numbers for a rear axle seal & bearing job ?
I'm looking at the local Toyota dealer rear axle parts page and it seems like it is missing some items shown in the FSM
Screenshots below
So far, I have:
90369-48001 Rear Wheel Bearing
90313-62001 Axle Shaft Seal
90310-58002 Axle Shaft Seal
42423-60040 Retainer
42423-60030 Retainer
It's not clear which of the two retainer p/n's listed above is the one that can be re-used in Tim's video above ...
Maybe someone who has done the job can chime in ?
Can someone confirm if
43425-60010 is the correct snap ring ?
I don't have a part number for:
_ the FSM shows a rubber O-ring in addition to the oil seal that is inside the end of the axle housing
_ the axle / backing plate serrated bolts
_ the plate washer that goes between bearing retainer and wheel bearing
_ the gasket for the oil deflector
.. does someone have those ?
I'm not seeing a Rear Axle seal thread in the FAQ - maybe this could be it Admins ?
