Rear axle oil seals
Long Island, NY
Are these oil seals reusable. I neglected to get replacements out of forgetfulness.
Are you talking about the filler and drain plug washers? They might not be but I serviced both diffs last week and had to reuse the washers....so far so good, no leaks. I did get new ones for the TC.
Nope. The actual oil seal on the axle where it slides into the axle housing for left and right sides.
Haven't done the 100 yet but every other Toyota semi-float rear that I've done you just slide the axle shaft past the seal when you pull it out. As long as you're careful you should be ok. .
If you mean can you remove the seal and then re-use it then that is a NO. Not sure why anyone would need to do that though.
