Sounds good, again thanks a lot for your advice.Negative STFTs indicate it's leaning back out due to the intermittent problem. But, it's obviously running rich more often than not, which is why your long-term trims are so high. I agree with checking the EVAP system as @aztoytec mentioned, along with the MAF connection (as it can cause some really really weird problems) if the EVAP checks out.
Is that screen shot while it’s warming up? Make sure it’s at operating temperature when checking it.
Certainly, I have techstream on an old laptop so I’ll bother with it this weekend. Thanks again!The evap purge valve is on the driver side top of the intake. It’s has two vacuum hose and electrical plug. One vacuum hose goes from the throttle body to the purge valve. The other from purge valve to hard line (then to canister).
The easiest way to check your issue would be to pinch off the vacuum hose from the throttle body to the purge valve while watching your fuel trim and see it it goes down.
There is other ways to properly checking the purge valve with a scan tool commanding it off and on while checking for operation and vacuum.
A few dollars in vacuum hose from the local auto parts store may be all you need!Quick inspection of the hose, show they’re probably the problem. The small hose to the little vacuum cell is cracked, and the hose going to the TB if I squeeze it, it’s gonna crumble. It sounds like I may have been over thinking this way too much.
Just FYI but prolonged running with a problem like that will throw off many, many learned parameters in your ECU. Once you fix it, I'd disconnect the battery for about 10 minutes. That will re-sent the learned ECU parameters to factory and allow it to re-learn under the hopefully corrected vacuum/air/fuel conditions.
Plug off that vacuum port at the throttle body and see if your full trim goes down….
There is a possibility that your purge valve is leaking and/or sticking open creating a vacuum leak, which would increase your fuel trim and give you p0441 and p0455.
You can also disconnect the connector and vacuum hose from the backside of the purge valve(going to the tank) and see if vacuum is present all the time.
Disconnected connector and fuel side hose disconnected there is no* vacuum.Plug off that vacuum port at the throttle body and see if your full trim goes down….
I did try that, but it didn’t do anything. I am sometimes seeing readings up to .5g/sec over 4g/sec. However it’s pretty close to 4 at idle warm no ac.The O2 sensors that monitor air/fuel ratio for setting fuel trims are upstream of the cats, so cat function should not affect them. 25%+ fuel trims indicate the engine is either getting air somewhere past the MAF (vacuum leak), has an incorrect MAF reading, or the fuel supply is low.
Did you try unhooking/rehooking the MAF connectors yet? What are your MAF readings at idle (in park, HVAC off, with the engine warm)? That's free/easy to check.
Sure, I have quite a while considered it to be fuel related but haven’t thought much about it bc it has been cold the last few months. Every now and then, after the trucks been driven somewhere and sits for an hour to 2 it’ll be slightly hard to start/ almost stall out as if the fuel pump isn’t staying primed, however the vehicle hasn’t sat long enough for cold start fuel prime.That's a pretty typical MAF reading. Seems like the problem may be more air getting in or fuel pressure related.
