OK,
So Im rebuilding my transmission/T-case and the bronze bushing in the transfer case hi gear was worn past spec.
I just finished pressing the old bushing out.
The bushing is split, and with a hole on the opposite side of the split, I can only assume to feed oil in/out of the bushing.
The gear is slotted from end to end in the bore in two places, 180 degrees apart.
QUESTION;
The original bushing was installed with the hole 90 degrees (approx) from the groove in the gear bore. The hole and split are 'blind' and flush in the bore of the gear.
My thought was to install the new bushing so the hole lines up with the groove to assist in feeding oil.
The only drawback I can forsee, is that then the split in the bushing would also line up with the groove 180 degrees apart and potentially under supported?
Otherwise, WHY is the groove in the bore of the gear anyways if not to feed oil to the hole?
Maybe Im overthinking this, but dont want to do it twice and cant find reference in manuals.
Thanks!
QUESTION;
Thanks!
