This morning I popped a P0401 code, so I have been reading up on how to either fix or bypass the system here on MUD and in the FSM.
As a temporary fix I went outside to see where the resistor should be placed to do the bypass and to my chagrin, the wiring harness heat wrap has been heat blasted to near disintegration!
Luckily, the wires underneath appear to have survived and to not appear to be melted. I will investigate further and re-wrap it when I have the chance to.
In the mean time I need to disable the EGR system to prevent the wiring harness from frying.
I am still learning about how the egr system works but from what I have read, the system will NOT pull hot exhaust gasses back through the intake runners IF the 2 vacuum hoses that are connected to the throttle body are capped as well as the 2 ports to the EGR Vacuum Modulator (the space ship on the PS side with 2 PS ports, 1 DS side port and a port on the bottom).
Is that correct? I'm worried that if I start capping and plugging those lines I will end up with an epic failure like what happened to Grench:
https://forum.ih8mud.com/80-series-te...-meltdown.html
I cannot see where the exhaust gas has been spewing from exactly, but my best guess would be somewhere near the EGR valve where it screws into the round pipe (not where it bolts onto the intake manifold).
I've been looking over the FSM and it looks like the exhaust could still spew from the EGR unless it is completely removed and capped.
Is that true or will capping the vacuum lines that go to the TB prevent exhaust gasses from being sucked up into the EGR?
I am at school right now and my tools are at home, so capping the vaccum lines in order to limp home without frying the loom would be great if it will work.
Thanks in advance!
Edit: I have been reading this post by RT that states that the system can be disabled, but I just want to be sure flaming hot exhaust gasses won't be able to spew from the system and fry the loom.
Thanks in advance!
I have not nor do I plan to delete the EGR on my 80, there is just no good reason to do so, unlike the 3FE you cannot gain much working space by de-smoging a 1FZ,
But I do know the EGR system and hypothetically if I were to it would go something like this:
The temp sensor resistor is detailed in another thread, that tricks the ECU, that is the ECU's only window into EGR operation,
You could then unplug the two vacuum lines on top of the throttle body that go to the modulator, plug the ports on the TB and on the modulator. Depending on how discrete you are with you plugs and how good the inspector is it may or may not pass the visual portion of a smog inspection,
EGR is then disabled with the parts still in place, easily reinitiated
If you wanted to go further and remove the parts:
Unplug the VSV and cover and seal the plug to prevent corrosion of the pins or a short from water, possibly by packing the plug with dielectric grease then wrapping it in electrical tape and then heat shrink.
Remove the vsv and its bracket under the intake, plug the ambient line at the T with the purge valve, plug the bottom of the hard line that passes through the intake, cap the top of it also,
Remove the modulator and its bracket,
Remove the EGR valve and EGR pipe, source a cap for the EGR outlet on the head (good luck) use a new gasket as a template to fabricate a block off plate for the open port on the intake manifold, 5/16” 7075-T6 aluminum worked well for the 3FE, install both.
