For Sale Ready for the beach beautiful Corvette Yellow fully built 1972 FJ40
This Cruiser build was recently completed and has
less than 3000 miles on the build.
No expense was spared and you are looking at years of
countless hours spent to get this cruiser to what it is today.
I appreciate your time for looking at this truly one of a kind vehicle.
Watch Video:
Video
Exterior:
Fully metal finished prior to paint
1976 Windshield Frame
Front bumper built into an air reservoir which features a water drain and is setup for a Warn Winch (Winch was Stolen)
Rear bumper made from 3”x 5” ¼ wall tube and features a trailer receiver with flat four trailer wiring plug
Hood Shaved: Took off the wind shield hold down latches and resting blocks
Under the fenders and hood got sprayed with rocker shutz for added protection and sound dampening for comfort
Upgraded Head Lights
LED Tail Lights
Custom Front Turn Signals
New Complete Best Top Soft Top with full or half doors
Body Armor made of 3/16 steel diamond plate and then Powder Coated in Hammer Grey
Custom One Off rocker guards are made out of ¼ diamond plate and Powder Coated Hammer Grey
All most everything assembled with Stainless Button head Fasteners: All were polished before installing
Interior:
Rebuilt the floor and got rid of the hump in the middle of the floor( not the dog house) plasma cut the floor and welded in new steel did the same with thing with where the fuel tank used to sit
Custom built dash made out of 10 gauge and powder coated in Hammer Grey
All New Water Proof switches in the dash
New Auto Meter gauges
Kenwood Stereo system plus 600 watt amp
Tilt Wheel with Borgeson Steering components
Billet Steering Wheel with a leather grip
Custom Built One Off Billet Accessories including: Head Light Switch Knob, Steering column levers, and Shifter Knob
LED Interior Lights
Custom built full family roll cage, stereo speakers are built in with wiring ran inside the cage
Sprayed the inside of the floor with bed liner spray
After Market Interior Heater
Custom Bucket Seats
Factory Fuel Tank was removed and a custom built tank built for installation between rear frame rails. 1/4 Plate was used for the bottom of fuel tank for added strength and safety
All most everything assembled with Stainless Button Head Fasteners: All were polished before installing
Most parts were powder coated before installing.
Drivetrain:
Fully Built 350 CI Chevrolet Small Block with w/ Edlebrock projection (multi Port) Fuel Injection
Advance Adapters Bell housing for transmission
Advance Adapters Rear transmission mount and Motor mounts
Completely Rebuilt Toyota landcruiser 4 speed transmission: All new bearings seals and syncros
Advance Adapters Heavy duty Orion 35 spline 4:1 Transfercase
High Angle Drive line of Paradise, CA New long slip front driveline, New CV Rear driveline
Stock cruiser axles with 4:10 gears
Front and Rear ARB Air Lockers with ARB Compressor
Also has a York Air Compressor for On Board Air System
All new 12 Circuit Painless Wiring Harness
All sensors and computer are new
Optima Yellow Top Deep Cycle Battery
Suspension and Handling:
Spring Over Axle Lift
Cut and turned the front axle 12 degrees to allow for proper pinion angle and proper factory caster angle
Custom built steering rods with hyme joints
Front shackle reversal: DOM tubing used for the frame rail sleeves
All new Rancho bushings through out the rig
New Rancho RS9000 Shocks
Rebuilt Brake Booster
4 wheel disk brakes with all new brake lines and Stainless flex lines: Toyota Front Disc Brakes / GM Conversion Rear Disk Brakes
Saginaw Power steering conversion: With Power Steering Cooler
Rims: 5 - 10”x 15” Chrome
Tires: 5 - 35x12.50 BFG Mud terrain
Watch a Video of this Cruiser on YouTube:
Search: "1972 FJ40"
"CruiserInnovations" is my User name on the YouTube Account
$34,500.00
530-966-1300
