- Vehicle Model
- 80 Series
Without shipping
$90 -New Weatherstrip, Windshield - 56121-60100
$20 - front floor mats used - fair condition$100 - ‘94 sun visors grey - very good condition
$250 - Collectors Edition wheels with lug nuts
$225 - Box of random spare seals-n-things
- Rear axle seals - new
- Rear hub gasket - new
- Rear/front hub stud bolts - new
- Spindle holder bolts - to pull off
- Front hub lock washer - new
- Front hub gasket - new
- ABS gaskets - new
- Water bypass O ring - new
- Radiator cap - new
- Cruiser Outfitter - fish scale - used
- Wits End - 3 piece JIS insert bits - used
- Wits End - PS pump holding tools
- Toyota FIPG - more than half left
- Wits End - Modified 54mm Hub Nut Tool- V2
- Wits End - Axle Seal Offset driver
- Otramm - crank holding tool v3
[td][/td]
$ 25 each - DAN5:1511X U-Joints - new
$375 - Dobinson Flexi coils (C59-614V 4" Front) and Flexi coils (C59-615V 4" Rear) - 500 miles on them
$90 - New Dobinson 5 degree correction plates
$200 - Man-A-Fre 4” Drop Brackets - new
$60 - Dobinson - Rear sway bar extension kit side chassis mount - new
$50 - Delta (DVS) - Front Swaybar drop kit - new
$300 - ARB rear adjustable upper control/trailing arms (UTA30360) - new
$75 - eimkeith rear panhard correction kit - new
$90 - Idle Air Control Valve/Throttle Control Motor 1FZFE - tested from Cruiserparts
Will add photos shortly
