Radio/Nav not cutting off
I have discovered that my sunroof drain on pass side is clogged. We got a ton of rain in the last two days and it filled up my passenger floor. At the same time my stereo and Nav screen refuse to cut off Even when the key is out and door has been open. Has anyone else experienced this, ideas for fix?
RobRed said:
Disconnect it and make sure the connectors are dry. To remove the brain you would have to take out the seat. If you feel around under the seat is it damp?
It did not appear to be damp but it's hard to feel all the way under. I'm hoping with he warm days tomorrow and sat I get better results. If not I'll pull the seat. Thanks for this feedback so far.
RobRed said:
I will look at the fsm to see where upstream the connectors might be. I suspect something behind the dash near the ECU could also be a possibility.
That area is def wet. The water ran down the pillar from sunroof at windshield and wet the side of dash and in front of fuse box going to the floor.
Update, the weather was favorable for drying out the rain water and I let it sit over the weekend. I did blow out my rain gutters which were clogged and water is draining out the wheel well now.
The radio and nav are now cutting off properly and seem to be working fine.
