Leaking coolant. Could not figure out where it was coming from. Looked like either from the bottom of the radiator or the water pump bearings failed and coolant leaked out onto the fan clutch. Front of engine bay is covered with coolant. Pulled the water pump. A little play in the shaft. Bearing failure? Perhaps radiator is is leaking near the bottom (the only place I saw coolant this morning after sitting all night, before I started removing water pump.
Before replacing radiator, I was going to have it pressure tested. Where in Durango is a good place to go?
