12mm socket, 12mm combination wrench (fan), lots of extensions (to get at lower bolts on radiator mount), 14mm socket (serp tensioner), 10mm socket (engine cover and intake hose/resonator box), cable hose clamp pliers, radiator hose removal hook tool, pliers (for random clamps), Phillips screwdriver (for screws at top of grille).
Once you're that far in it is pretty trivial to replace the smaller cooling hoses between the thermostat, oil filter cooler fitting and throttle body.
Depending on age and condition, it is a good time to do serpentine belt maintenance or go as far as the water pump. Everything is out of your way at this point.
Agree with Julian S - depending upon age and mileage, the heater tees and hoses at the back of the engine are worth doing.
One tip - crack the fan nuts loose before taking off the serpentine belt.
I didn't do this, but in retrospect, it might have been easier to remove the radiator side brackets before removal. I got it out without that, but you'd have more room to get it by hoses on one side and the battery tray on the other if you took them off.
