Cross cross-posting this from the 80-series forum because I wanted some insight from you guys also:
I'll be replacing my radiator this month and I've been looking through several threads about what radiators to use as a replacement for the '96 HDJ81. There seems to be conflicting answers on almost every thread I look at. Some say to get the 3FE radiator or other ones that drop in but are only manual transmission and then run your own trans cooler that bypasses it. Others suggest different radiators that fit with a little bit of help from custom brackets etc.
My question is this: what radiator drops in with little to no modifications into a 1996 HDJ81 with a 1HDFT that still maintains the OEM trans oil heat exchange inside the radiator? The current radiator in the cruiser is part number 16400-17060, but they are discontinued, and I can't find any for sale anywhere or I would get this.
Two other options that I looked at that retain the trans oil heat exchange (I believe so) are:
go.skimresources.com
and
Are these pretty much direct fits?
Lastly, I've read that the A442F is prone to overheating, and many people supplement their cooling with an auxiliary cooler.
How necessary is this if never towing a trailer? Most that would be towed is a small boat rarely. Along with this, this vehicle will see several long-haul trips where we drive for several hours, and there will be times when it is on steep climbs when we head out to the mountains.
For the trans cooler, I've been looking at the Derale fan coolers so that I can mount in inside the frame, leaving in front of the radiator open for an intercooler down the line.
At the same time of servicing and changing all of these things, I will also be getting a new thermostat, fan clutch, and coolant + trans temp gauge.
Just wanted to hear everyone's opinions about those two radiators or if they have a link to the 16400-17060, and what everyone thought about the trans cooler.
JR2222J Radiator suitable for 80 Series 1HZ 1HD-T 1HD-FT Automatic Transmission - HD Automotive
and
Toyota 16400-17031 (1640017031) RADIATOR ASSY
Toyota 16400-17031 (1640017031) RADIATOR ASSY. New & genuine Japanese car parts. Fast shipping. Low prices. Request a quote from Amayama Trading Co. online.
