For Sale R151 trans for 1HZ with Tcase with 4:1 crawler gears only 20K miles
joekatana
GOLD Star
Texas
  1. 70 Series
I am selling the R151 transmission that I had used in my HZJ73 crawler for a few years . I took this transmission out of a wrecked 2016 HZJ76 from the red cross with less then 10k miles on it at the time .
The t-case has been machined to fit the 4:1 Sumo gears and been converted to manual shift instead of the vacuum shift.
It works perfect and I was going to use it again in my new current build but someone decided for me that I should run a H152 with a 80 case in that new build and donated one for it to , thank you Galen ;-)
So long story short this one is for sale , I have run R151's behind 1HZ, 1HDT and even 1HDT FT engines and always without drama unlike what the interwebs and social media forums are feeding you . I also feel that they are more pleasant to run on the road then a H55 as the shifting points are different . I have one in my KZJ73 that I daily also and still have a extra spare that I probably will never need so this one can go.
2500$ plus shipping
It works perfect and I was going to use it again in my new current build but someone decided for me that I should run a H152 with a 80 case in that new build and donated one for it to , thank you Galen ;)
2500$ plus shipping
I have been contemplating a swap in my kzj78 (auto) to an R151f. Will this R151 suffice for a good swap?
Im still learning the different models of trans and such within the world of cruisers.
I understand i would still need to spurce all the associate clutch components and a bellhousing.
I am located just south of reno nv, qhere are you located? Let me know if you think we can work a deal.
- Josh
- Josh
This one is sold but I do have another R151 here from a LJ73 , I think that one should bolt right up yo the 1KZ
How much are you asking?
Where are ya located?
Do you have just the trans or do you happen to have any other parts? (Flywheel, pressure plate, clutch fork, throughout bearing, pedals etc?
Thanks,
Josh
Thanks,
Josh
Just the trans but if you have a lhd I have pedals also
How much would you ask for the r151 amd does it have a 1kz-te bell housing?
It has the 2LT belhousing on it , they might be the same though
Okay, how much were you lookin to get for the r151f?
As the condition is unknown I take 500$ for it . I got this out of a LJ73 with a blown engine so I couldn’t test it before parting the cruiser out
TX , just North of DFW
