R150F to NP203
Toronto, ON
Does anyone knows how to put NP203 transfer case behind R150F manual transmission on Tacoma?
I looked on the web, but can't find any specific information.
Please help...
Out of all possible transfer cases...... why an Np203? It's a big, heavy, chain driven case. I can think of many different cases that are better.
NP203 can be bolted in front of the '79 Land Cruiser TC.
I think there were some years of dodge 203s with 23 spline inputs. IIRC that is the version that is easiest to mate up to an AX15 - which is very similar to the r151. I don't know for sure if the output shafts are the same though. Most of the ax15 components can be swapped around with the r151, so it's possible that you could swap in an ax15 output shaft if necessary.
Not sure about where you'd find adapters and things of that nature.
