Apologies for the long post. I'll answer your question and then you can continue on reading if you're interested.
Anderson PP45 connectors come two ways: as separate individual connectors or fused. If you order them as separate connectors you can slide them together any way you want even in a bundle of 4, 6 8 etc... If you order them fused then you order them vertical or horizontal. Whatever you do, get a vinyl boot to slide over them as it will help the connector stay inserted in the Yeti.
Brccee AC 10PCS FR PVC Cover Flame Retardant Sleeve for Anderson Powerpole Connector Housing
Perhaps you have a good crimper, I do not, so I had Powerwerx make my cables for me:
Custom DC Power Cables | Powerwerx - https://powerwerx.com/custom-dc-power-cables
If interested then read on McDuff!
I have concluded Goal Zero does not have a good car charging option. And how could they? Would they say "buy our unit X, put a 50A line to your battery/alternator through to your passenger compartment, fuse and ground it properly and you're good to go"? Nope. I don’t think so. LOL. The only way you could go all Goal zero would be to wire in your own 2000W inverter and plug their 230W or 600W AC charger on to that.
Regarding Goal Zero, the MPPT solar controller and interoperability:
IMHO, Goal Zero did a good thing by building a MPPT solar controller into their unit on the X series. The outputs on the X series are also regulated. This eliminates the need to have separate regulating devices on the charging inputs and supply outputs. But you have to understand the quirks. Not every manufacturer does what Goal Zero did so you will find that charging directly off the alternator/battery using the other 12-12V Orion or just directly with cables may work for other vendors. There are reasons that I went with Goal Zero that are beyond the scope of this thread.
Consider what their MPPT solar controller has to cope with:
Goal Zero itself makes 3 AC chargers, multiple solar panels and they advertise interoperability with solar panels made by others provided they stay within their advertised parameters. Their 3 AC chargers are rated at 120W (it comes with this one), 230W and 600W. The latter two use the Anderson input. So that MPPT controller is pretty robust, I deduced.
Regarding the Victron (a good volt meter is your friend):
- It can function as a battery Charger with different battery charging profiles or as a Power Supply. Set it to be a Power Supply by choosing Function->Power Supply in the app. This eliminates any notion that it has any MPPT or other quirky characteristics. That you can do this is why I love Victron.
- Set the output voltage to 24V.
- Set the input voltage lockout and restart values to be something based on your car's unique characteristics. For example, this morning my 2018 LC with the OEM battery had, after sitting for 2 days, an engine off voltage of 12.52V @ 80F.*
- Your running voltage will vary so set the lockout accordingly. You want the Victron to shut off very quickly when you stop the car – ideally within seconds.
- My LC charged while idling at 13.97 volts after starting with an early instantaneous spike or two at 14.1V.
- It then settled to 13.9V after about 5 minutes at idle.
- Once the engine was off the battery read 12.67V.
- Set the Orion's lockout value to 12.8V and the restart value to 13.5V and you should be fine at all temperatures. But check on your own to see what YOUR car does and set accordingly.
NOTE: you can download the Victron Connect app and experiment with it without even having the Orion in hand as it has a stand-alone demo mode for each product. Did I mention I love Victron? I mean, who else even comes close to that?
*Remember that 80F temperature?
I first tried integrating the car with the Yeti in the dead of winter and was puzzled by what I observed. I was actually able to get the Yeti to charge direct-connect to the battery without the Orion in the dead of winter for a couple of minutes when the car started. Why? The LC's alternator is voltage and temperature sensing. It raises the voltage in colder weather and lowers it in warmer weather. On measurement, in very cold weather the alternator put out over 14V briefly until the battery charged and the engine compartment warmed up. Once it did the alternator dropped its voltage and the Yeti completely stopped charging. I saw the same thing happen from my 2nd battery which is connected to the REDARC but only in cold weather; it appeared the REDARC does the same thing. I tried the same test again when the weather warmed up and that minute of direct charging without the Orion dropped to a few seconds. Don't be fooled into thinking you can charge the Yeti X straight off the 12V systems like I was attempting initially. If you're wondering whether or not I drove around town doing errands with a voltmeter checking the battery voltage at each destination you're right. I did. LOL.
I remember my dad and me piling into my parents’ 1960 Rambler with all of our stuff to go weekend tent camping with some friends. Just as we’re about to leave my mother flies out of the house holding something yelling that we had forgotten the marshmallow forks. Today I’m convinced she’d be carrying a multi-meter.
