pulling
Keene Valley, NY
My 62 is pulling to the right on braking. Strangely, it only happens at the end of the work day on my drive home. Next morning, it brakes straight all the way to work. I rotated the tires this weekend, front to back, and noticed a little weeping on the driver side caliper. Could the pistons be seizing on the DS causing the truck to pull right? Is it difficult to rebuild the calipers?
-chris
Have you had someone pump the brakes as you watch? It could be loosing just enough pressure, if its weeping, to where the pad isnt being pressed hard enough against the rotor. As for rebuilding them, I've tried a couple times and got eh results. I buy new ones now.
I agree replace it, Napa has 10% off if you reserve online and pickup in store I believe right now. I like there brake products myself always have had good luck hope this helps my fellow 62 lol
It probably just needs some dents in the passenger side less wind resistance hahaha
Burl
...via IH8MUD app
