Pulling under braking
Hi,
I have a 2L LJ-70RV-KR.
And I am having massive problems with the car veering to one side (usually left, but also sometimes right) under even slight braking.
This is an issue we have lived with for a long, long time. Which was due in part to near daily river crossings, and they would eventually dry out. (And frequent cleaning/servicing of the rear drums, of course.) We haven't done any crossings in the last 6-odd months.
About two months ago I started noticing something; coming down from an altitude of 1300m through to about 450m the brakes were perfect, but as soon as I reached a plateau of around 300m, the brakes started pulling erratically almost always to the left but something to the right too - I assumed the brakes overheated from driving. And actually got worse, the lower I got (maybe I am imagining this, I am not even sure at the moment).
Going back past the 3-400m altitude, the brakes started getting better and better, I assumed we were lucky. And I didn't have a single complaint for the next month of driving around the 1300m range again.
Mechanic said overheating/dirty/blah blah blah. I should upgrade to disc-brakes and I'll be much better off (and so would his pocket).
Now last night, I again came down from the hills and the brakes started pulling as soon as I crossed the very same point as last time.
I really don't think that this is a coincidence.
What could be the problem here?
Any ideas and advice are very welcome.
Does this 70 have discs or drum brakes on the front?
Drum brakes can provide quite good stopping power,but they can not shed heat as well as a disc brake.
I dont think adding disc brakes to the rear would stop the pulling as it is the front brakes that cause the pulling.
It sounds like your brakes are fading from the steep inclines.
I would suggest using your gears to keep the speed down and only using the brakes when you have too.
A change of brake pads/linings (You would need to contact someone who is knowledgable on this)and machining/replacement of the dics/drums may help with fade.
