Pulling my GX behind box truck
Kansas
I poked around looking for a good answer and couldn’t find what I was looking for. So, have any of you towed your truck? Is there anything with the AWD that needs to be “set” or in neutral for the pull. Should I rent the trailer or would you be ok with pulling it with the dolly? Thanks for any info. CO back to KS.
You can flat tow it or get a trailer; you can probably use a dolly if you remove the rear driveshaft and put the t-case in N.
You cannot use the dolly without pulling the rear driveshaft.
