How low should I go with BFG MT 305/70 x 16 tires on the trail?
Thanks, I have had it down to 12 before. Just curious if some people are comfortable going lower, and what there experience has been.
On a regular radial tire without bead-locks I wouldn't go lower than about 9-10psi.
IMHO i think that's a bit low for a regular tire. I personally wouldn't take a non-beadlocked and non "wheeling" type tire below 15psi.
by wheeling type, i mean mtr, swamper, pitbull...any tire designed to go low air.
Chad, just keep some lighter fluid around, setting a bead with fire is fun!
Trail PSI is such a function of trail conditions, tire type and tire size that there is no one size fits all. For a stock size street tire 20psi seems to markedly improve traction while increasing sidewall puncture danger.
I'd increase pressure for sharp rocks, decrease pressure for snow or sand. But if you're in the Sierras on snow where sharp rocks lurk under the snow, you may not want to risk 20psi. For something like Moab 25psi is fine for stock tires due to the smooth rocks and excellent traction.
If you have offroad quality tires, you can go lower as they're tough enough to handle the sidewall stress. If the tires are larger, again you can go lower. But if traveling alone and having only a single spare, I'd raise pressure again.
So, lots of things need to be considered. It's not a single answer.
DougM
