PSA: Replacing Rear Sway Bar End Links
Pensacola, FL
Just posting a quick PSA because looking through other threads I haven't seen too many other people with the issue. After putting my Ironman lift on my LX470, I was putting the Trail Tailor sway bar end links front and rear on and my drivers side rear bolt/sleeve fused together. I had to get a pry bar and bend the actual end link off. So now I have to wait for a couple parts before I can finish. Should've just gotten them to replace in the first place, but hindsight is 20/20.
TLDR: If you get the Trail Tailor rear end links get these part numbers as well below in case your sleeve is fused like mine.
Bushing: 90385-11021​
Sleeve: 90560-10275​
Oh awesome glad I'm seeing this, placing an order for other parts and have the end links ready to install. Appreciate the heads up man!
You probably won't need them, but they're also only like $4-5 a part so if you don't want to risk it!
