PS Pump Questions
Bogota, Colombia
Website
www.4x4xcolombia.com
Ok, so i have a hydraulic winch... thats where this is headed at! a while back i started noticing my ps pump was making noise, but i never really paid attention to it. Last sunday i was wheeling was forced to use my winch (i rarely use it because its SOOO solow). As i was pulling i noticed two things: one, the wired control is about to kick the bucket and needs to be replaced and two, the PS pump is on its way out also... which is where my question comes in.
Does anyone know what the specs for GPM and PSI for the OEM PS pump? Has anyone upgraded their PS Pump for a better one (ie. More GPM and PSI)? If so, which one... i dont want to go out and buy something that wont work, have to adapt it and then see it stop working in a bad situation...
Thanks!
:cheers:
Thanks!
:cheers:
Is this a 3F type pump? A shop that specalises in pump rebuilds told me the noise can be caused by a varnish like build upon the vanes and plates that causes a hydraulic groan . They recommended a a PS treatment in a bottle to clean it up on the inside and it worked,for me anyway.
Auto transmission treatments are much the same thing
The pressure should be 1138 psi mimum with the valve closed at idle .
Then its tested at 1000 rpm and 3000 rpm and there should be not more than 71 psi difference.(at 1138 psi minimum
You should download the free body and chassis manual 84-90 and read the test to fully undestand it.
Its at the top of the 70 and diesel forum.
IMO ,they work fine with 33 in or under tyres and I would rebuild yours if necessary
Manual says the flow control valve sometimes need replacing ,otherwise its usually the vanes and plates that wear out.
The pump on my 1HZ needed a new main shaft from where the o ring had worn a groove in it and I guess the 3F pump could do the same.
Rosco, ur the man!!! thanks... i had been looking for that type of info for quite some time.
Yes, it is a 3F PS Pump you are correct. By any chance do you know the GPM ratings on them? im asking basically because of my winch... i get a bit of whining from just the 33's and i imagine it could be the rust build up, but when winching i cant turn the wheels and winch or the winch will completely stop.... Do you happen to know any aftermarket or heavy duty PS pumps that can work with the 3F withought any or few mods?
GPM =gallons per minute ?? I cant see anything like that in the FSM.
On other PS pump powered winches,the winch will stop when you need the steering and they are all slow.
A lot of the 40/45/55 series guys use the Saginaw pumps but I know little about them. Maybe ask on their forum if no one here can help.
IMO you would be better off with an electric winch and rebuild your old PS pump or run a hydraulic pump from the PTO;)
I started with using the standard PS-pump but this has the disadvantage that the winch will stop when the wheel is turned.
So I bought a dedicated hydraulic pump and connected that to an A/C electric clutch. This way the pump doesn't run when the clutch is not engaged. The pump is driven by a v-belt that sits on the 'spare' crankshaftpulley that I've because my rig lacks A/C.
It's still fairly slow and if I had to do it once again I would use a slightly larger pump. The one I have now has 6,5 cubic cm per rev. I think around 9 ccm per rev would be better.
I used the winch several times up to it's max pull capacity (where the overpressure valve I incorporated kicked in) but the V-belt or clutch didn't budge.
Ron:
i guess you would need more like 15l/min so more like 13..15cm3 per revolution - at least these are the values required for MileMarker winches and I would believe that for others as well.
I also use single v-belt and it can transfer about 2kW power which is enough for 12000lbs winch to go at about 2m/min. I did some seroius winching and no problem with this single belt
Serious winching = 4 hours of winching through the mud hole with breaks just for relocating the hook to another tree ;)
I am definitely interested in more information, if both of you can give me the insights, and what you would do if you had do to it again...it would be great! (the more details you can give me the better, no one seems to know how to make this darn thing make a little bit faster!!!
My rig does have an A/C so if you can keep that in mind when making recomendations, i would love it! thanks alot!!
Ron:i guess you would need more like 15l/min so more like 13..15cm3 per revolution - at least these are the values required for MileMarker winches and I would believe that for others as well.
Hmm, something strange happening here to the quotes. Never mind.
Well, some more info then:hhmm:
I agree on what WojtekSz says about pump capacity. But at the time I build my setup I was not aware about the amount of power I could transfer through the A/C clutch. I therefore choosed a setup in which I rather went for speed than for torque.
By choosing a set-up where I need 2000 to 3000 RPM (engine!) to get the needed volume I wanted to avoid to have to transfer a large torque through the clutch.
I now know that a larger pump (indeed WojtekSz:cheers:) like 10-15 cm3 will work better. This way the engine can turn slightly above idle and you would still have the needed flow rate to have normal winch speed.
Another thing I took into account when I choosed for my set-up was that, by altering the engine-speed I also could regulate the winch speed. Nice idea but there is hardly any need for this I found afterwards.
So my advise now is: use a larger pump than I did.
As you see I've put three photos in this message.
The drawing is about the connection between the pump and the A/C clutch. I had to keep in mind that this kind of pump does not allow a pulley to be bolted to the pumpshaft and to drive it by a belt. No radial forces are allowed. All you are allowed is to turn the shaft. Sounds a bit strange but this is because this pump has no real bearings. For me that was no real problem because I was going to use that A/C clutch that has a housing and bearings by itself.
If yo look at the drawing ( sizes are just applicable to my setup!) you can see the blue part. This is the housing for the A/C clutch and carries the forces excerted by the V belt to the crankshaft.
The Red part is a kind of 'transfer'. It is sitting inbetween the A/C housing and pump-body (the red arrow on the photo with the view on the pumpassembly)
In there are two small bearings, guiding a bushing that has teeth at the inside and can slide (don't know the english expression for it, but it's similar to the sliding part of a drive shaft). This part connects the pumpshaft to the A/C centre shaft, without transferring any radial forcesbut allowing some axial play.
At very left side (yellow, I hope it's visible) you then find the schematic of the pump shaft.
The A/C clutch is engaged by energizing it and only then the pump will run.
The hydraulic fluid then passes a pressure regulater (see picture with the squarish part) because the pump can deliver more than twice the allowed pressure. The regulator is is calibrated to the max allowable pressure.
After this the fluid gets to the valves of the winch, electrically controlled for in and out. After the winchmotor, the fluid is pressureless and enters a cooler that sits in front of the engineradiator. After the cooler it returns to the pump. In this returnline there is a T-connection that connects to a small reservoir (about the same size as the power steering reservoir)
With this setup I've been winching under fairly harsh conditions.
Apart from the winch speed (slow) I'm very happy with the setup.
Three examples:
1. A Landrover Discovery buried in a ditch in the mud, halfway the doors. The owner was able to find a connection point where he could hook up the cable by feel. I was afraid to winch ( the cruiser connecte at the rear to the guardrail of a freeway) to full capacity as I was afraid of damaging the Disco (10,500 lbs pulling force!) But he wanted to have it that way. So I put strain on the cable and then waited until the Disco gave a bit, put strain on it, waited etc. Took almost two hours to move it for about two meters and free it from the suction of the mud.
2. Tunesian desert (Sahara) A Nissan Patrol, stuck in sand inbetween two dunes. Flat on it's belly. Took about an hour of hard wiching. No problem. No overheat.
3. Moroccan desert (Sahara) This time I got stuck myself in a very deep pit inbetween dunes. Sand was so soft the rig was flat on its belly, could not get it on top of the sand despite sandladders. Sand was like water. Had to winch over a distance of about 30 meters under hot (35deg celcius) conditions. Here the enige temp went up because of poor airflow after about an hour of winching but the hydraulics were okay.
The only way to have a fixpoint was to put one of the other rigs (an 80) just over the ridge of the dune. Standing on the ridge didn't work All I did then was just drag it towards me instead of winching myself out.
It took about two hours of hard work but we managed. If I had been on my own I never could have freed my rig. A ground anchor didn't work.
If your A/C in in the way and you cannot accomodate a separate pump then the only option is to have a larger PS pump. Or....and that would be MY option: have a PTO-driven pump.
Disadvantage:1. Costs (and here in Europe it's hard to get a PTO-gear) 2. You have to be in gear and to make sure you don't over-rev the pump. It then is also a bit complex to have power to the wheels and winching. The moment you press the clutch you also loose your winch. To winch without spinning wheels the transfer must be in Neutral.
Ron:
the experiences similar to what you have described made me look into hydraulic winches...
electric are much better for easy jobs like rallying around the some wood or forest but still more like a play. That is where the faster the better.
What i am looking at now is a PTO option - seems that in Nordic countries they may have some to spare :)
Still, even with PTO pump , I would go for winching with transfer in neutral (no drive from the whels) as it is impossible to have synchronization between the wheels and the winch - weel, except for getting out of deep mud where there is no friction at the wheels ;)
Ron:
Wojtek,
I agree on your opinion on electric winches. If it gets to heavy winching for prolonged times hydraulics are much better.
I've seen electric winches starting to smoke after 10-15 minutes winching under max load, or their overheating switches to cut in after that time. And if that doesn't happen, at that time the batteries will start to wave the white flag, giving up.
For short quick jobs electric is much faster than hydraulic but as soon as a real job is to be done, there's nothing like hydraulic.
In general one would not use wheels when winching, but sometimes a bit of power to the wheels can help to dig yourself out of the dirt.
As far as PTO goes, several times I've tried to get one, (used - cannot afford a new one) but it's hard to find one and if you find one, there's always one willing to pay crazy amounts of money to get it.
For the time being I'll stick to my present setup as long as Father Christmas doesn't put a PTO in my stocking....:lol::lol:
I seen a couple for sale here in the classifieds but people are prepared to pay $500 and get out of bed at 5am to beat me there:frown:
Yeah, that happened all the time I wanted one. I once had my hand on one (bought it without seeing it because it was recommended by somebody who knew the seller, a French Company) and even handed money over. Then I got an excuse. 'Somebody had made a mistake and sold the piece to another person.' , they said. I didn't believe them. I think the other person overbid.
So, to avoid pains in my stomic I decided to keep it to my present setup unless I trip over one.:D
Rosco, Ron:
do you happen to know the dimensional requirements for pto for toyota lc70? I have run across a company making interestingly looking pto's but can not check if it would fit.
S&S Trucks - Home Page
Sorry, don't know the physical dimensions.
Tried to find a relation between the Toyota partnumber and their listing of PTO's, but found nothing.
Do you know power-trax.de - Offroad-Spezialitäten ? They have remanufactured PTO's but price is still around 500 Euro's
