problem with engine shutdown Toyota Bj43 1979
Warsaw
Please help. In my Toyota bj43, after replacing the voltage regulator, it stopped extinguishing the engine on the old one, which may be the cause
Sounds like an EDIC issue, since that is what’s responsible for engine shutoff.
Can you visually inspect the EDIC while turning off the engine?
You can see the rod working (albeit during startup) in this video:
I have a BJ44, it has wiring that has been modified many times. The motor mentioned above is missing.
A previous owner went to a manual shut off cable run to the dash. The picture shows it in the run position.
