Love a quick win to restore some sanity. Wonder if it’s original.
Did you try spinning the rotors and drums while stepping on the brake pedal?Well, I think I’ve exhausted my capabilities for now. Still have absolutely zero pedal with the car on.
•I’ve bled 1.5 liters including the LSPV total (another 0.5 this morning). There is almost no flow from the RF caliper. All others were clean bleeds with no visible bubbles.
•I was unable to get the RF pads out and I think that may be the culprit. It had more pad wear and seems to not be retracting. The pads didn’t look as bad as I recalled but it was dark. Would that cause no pedal though?
•both rotors are above 20mm (min is 19mm).
•I was unable to get the drum retaining screws off to pull the the drums. Ugh.
Probably going to pick up the Napa Total eclipse semi-loaded calipers later today.....or just tow it to @OTRAMM
any other thoughts @Stumpalama
@NearJetties you really need to start at the master and ensure it is properly set up and bled. Then check the caliper pistons for operation.
Focus on making sure the rod is properly measured and that you bless the shiite out of that master.s***e, I didn’t think about rebleeding the master. Going to get a dorman master bleeder kit tomorrow and enlist the wife so I can to the wheel spin test.
So as not to start yet another tire thread and get murdered, I am wondering which way to go. I like the looks of these but not sure if they’re a good all terrain tire. Don’t plan on doing anything beyond maybe fall crawl this year so keep that in mind:Finally got my own. And unlike my 4runner this one runs !
Needs tires, shocks and some cosmetic odds and ends. Making a list checking it twice
Maxxis RAZR MT 40 x 13.50 x17 I should be able to get them to you for about $350-360 each. I would need to double check my pricing.Starting to tire shop. Debating between some used but low mile KM2s (40x14.5-17) or new Patagonia Milestar MTs (40x13.5-17) The only reason I’m considering the KM2 is they come in a 14.5 inch width which I sort of like and thats what’s currently on the truck. I think they are from the end of the production run (around 2015). Thoughts?
