In another ironic twist, I have had lugs shear on the *FRONT* of my rig, approximately 1 month after I finally got the rear fixed.
Looking for practical experience on what size press I should invest in that should be able to press out and in the lugs. HF has a 6 ton desktop style press for about $70 - would fit in my wallet and shop area, and I figure I can always replace the bottle jack with a larger capacity and increase the available pressure.
Since most folks are recommending a 3lb BFG and brass drifts, should 6 tons be enough for a starting point?
Oh - I will be replacing *all* of the lugs on both front rotors, as well as having the remaining rear axle ones replaced. Not sure if its the 200k miles and the lugs are just tired, or if the rim spacers are doing it....so going to change lugs, and go back to my original 15 OEM rims and remove the 1.5" spacers, and just get some AAL for the rear spring packs to adjust the "saggy 60" syndrome, that was the original reason to go to 16" 31 x 10.50's. Will get proper backspaced plain steel rims and new spring packs when my wallet stops bleeding.
Anyone interested in a set of 80 series 16" AL rims? I'll have 5 here in the near future that will be available.
Glenn in Tucson
Glenn in Tucson
