Prado springs
Revelstoke. B.C.
For sale 3 pairs of LJ78 Prado springs-
One pair front OME med 25-30mm lift, only have about 6 months of use,(black ones) $100.0
Full set 30mm( 2front/rear) 30mm lift, the fronts look like heavies (thicker gauge),the rears are med. 150.0 or $80.0 a pair
I have more lj78 stuff here-http://https://forum.ih8mud.com/diesel-jdm-parts/279337-prado-front-clip-2lte-trans.html
Thanks
Joel.
100_2419.webpclip
Thanks
Joel.
View attachment 327959clip
Are the springs still available? They are both (F & R) OME?
Canada Post COD ok with you?
Let me know.
Cheers!
Lawrence
Sent!
I did fit an 80 series front springs for the Prado rear. A little bit high but I pull a heavy 9x5 trailer full of gravel or yard waste from time to time, it levels nicely when the trailer is full.
I just need the front lifted a bit to level it a little when not loaded.
Cheers!
Lawrence
Right on. I have the OME med in the rear, so the truck sits high when empty but when you put so weight in it she levels off. Thinking of putting some air bags in to help when she's all loaded up.
Joel.
OME med fronts are sold!
Got the OMEs and just installed them... I got around 40mm of lift which is nice. I have yet to road test the truck and check the ride.
Thanks for the quick shipping.
Cheers!
Lawrence
