I have a big 24v NiCad battery that was used to start airplane engines from a ground unit. It is made up of individual cells so you could run 12V. What are your thoughts on running this vs a standard second car battery. Immediate issues I think of are charging hassles/speed and voltage limited at ~12v not 13.4. I have an 8274 front winch and a warn tabor 9k rear winch.
Specs are
24VDC
84.7 lbs
43 AmpHr,
which would be 86 AmpHr at 12V if I use the cells in parallel. This is roughly 10 minutes of winching at a full 8,000lb on the 8274 or Tabor 9K. Problem is I'd have to charge at 86 amps for 1 hour to recharge the battery before the next pull if it was dead. What kind of performance are you seeing on you setups?
Chris
Specs are
24VDC
84.7 lbs
43 AmpHr,
Chris
