So i did several searches, but cannot find these problems out there, or my search is incorrect.
I picked up an 01 last month. I was given an aftermarket key with no remote as the only key. The only marking on the key is "Italy"
If i unlock the drivers door only with my key, then open the door, the alarm goes off. Is this normal? If i unlock all the doors by turning the key twice, all doors unlock normally and the alarm will not sound.
Also, if i open the drivers door and start the truck with the drivers door open, when i close the drivers door the power locks seem to unlock twice. I cannot find anything in my search that has this problem, but i think it is interfering with my key programming.
I had a dealer program a new Toyota OEM key for me, and they were "not able to" or gave up programming the key-less entry part. I tried myself but the truck will not go into programming mode. Is my only recourse to send the ECU to get re-programmed? This key DOES start the truck.
Last question - I was double checking to see if my aftermarket key could lock the glove box (master key) and it could, but now neither the key i was given or my new key will open the box. Any ideas? I dont want to just drill it out.
Thanks
Thanks
