Power door locks to manual door locks
Earth
Does anyone know how to make their power door locks to manual door locks on their 100 series? When I press the unlock button on my LC, the clicking sound comes so it's trying to unlock the other doors, but I have to go in and manually unlock all the doors one by one. The tailgate only manually opens from the inside as well. So I want to temporarily make it manual door locks so I can open the tailgate with my key in the slot.
yeah... you can't.... I sprayed some dry film lube up in every crack around the lock motor/actuator on my rear hatch (with it open) and it actually works MOST of the time now... (I used the little red tube that comes with the lube) being out in the heat will stop it from working.... I have a rod 1/4" aluminum with a J hook on the end about 36" long that i keep in the back, with it i can reach the lock from the pass side to unlock the rear when it fails to open... everytime I think i'll remove the panel and clean out the lock motor it's working perfect so i go on to other projects...
